2861| 0
焊接专业英语词汇 |
焊接专业英语词汇 (共35页,很全,以下是部分节选) 熔接fusion welding 压接pressure welding 焊接过程welding process 焊接技术welding technique 焊接工艺welding technology/procedure 焊接操作welding operation 焊接顺序welding sequence 焊接方向direction of welding 焊接位置welding position 熔敷顺序build-up sequence deposition sequence 焊缝倾角weld slope/inclination of weld axis 焊缝转角weld rotation/angle of rotation 平焊位置flat position of welding 横焊位置horizontal position of welding 立焊位置vertical position of welding 仰焊位置overhead position of welding 平焊downhand welding/flat position welding 横焊horizontal position welding 立焊vertical position welding 仰焊overhead position welding 全位置焊all position welding?熔焊时?焊件接逢所处空间位置包括平焊、横焊、仰焊等位 置所进行的焊接。如水平固定管所进行的环缝焊接 向下立焊vertical down welding/downward welding in the vertical position 向上立焊vertical up welding/upward welding in the vertical position 倾斜焊inclined position welding 上坡焊upward welding in the inclined position 下坡焊downward welding in the inclined position 对接焊butt welding 角焊fillet welding 搭接焊lap welding 船形焊fillet welding in the downhand position/fillet welding in the flat position 平角焊horizontal fillet welding 立角焊fillet welding in the vertical position 仰角焊fillet welding in the overhead position 坡口焊groove welding I形坡口对接焊square butt welding 喇叭形坡口焊 flare groove welding ………………
购买主题
本主题需向作者支付 1 机械币 才能浏览
手机版|小黑屋|机械村
GMT+8, 2025-9-5 01:09 , Processed in 0.016327 second(s), 5 queries , Gzip On, Redis On.
